Duplicated review issue
Hello @Max,
I got the issue same, Can I continue here, or I need to create different ticket for this issue.
Here is my site - [Dental Implants GPS to Guide Our Patients to Success | GPS Patients] (https://gpspatients.com/)
If you scroll bit to the bottom, you will find google review section: Screenshot by Lightshot
Please let me know what the problem is?
Hi there, @user20720 :wave:
The thing is that this user left this review for 3 different businesses ( Dental Implants GPS, Dental Implants GPS West Covina, Dental Implants GPS Reseda).
However, this review is no longer available for these businesses:
So, if we update your widget, this repeated review will completely disappear from your widget. Would you like to proceed this way?
Thanks for getting back to me,
Yes, Please you can proceed by that way, But the question is after that it will no longer repeated right? or not any other item as well? Right?
Thanks.
Not quite. The thing is that all reviews J.F user left for your businesses are not available on Google anymore. So, if we update your widget, all 3 repeated reviews by J.F will disappear from the widget.
All the other reviews in your widget won’t be affected by this change. Does it sound good to you?
Yes, Could you please update widget?
Done!
Check your widget and let me know if everything is fine on your end now :slightly_smiling_face:
I have reviewed the widget, and everything is working perfectly now. I really appreciate your prompt assistance in resolving this issue. Thanks for your support! :slightly_smiling_face:
No sweat!
If any further assistance is needed, we’re always happy to help :wink:
