Review widget not showing correct amount of reviews
Google listing says they have 190 reviews but the widget is only showing 78. Also, it will not let me view the testimonials. The feed appears blank.
place id - ChIJORKIPsCmc0gRn71ouxUDAVA
2x widgets - floating badge & all in one reviews
https://dev.dental-design-clients.co.uk/dentistry68/about/testimonials/
https://dev.dental-design-clients.co.uk/dentistry68/contact/
Happy to see new faces among us @nigel1 :wave:
We’ve fixed the issue:
Check it out and let me know if it’s fine :slightly_smiling_face:
Ah brilliant. yes, it is now fixed. thank you for looking into it for me!
No sweat!
If anything comes up, we are always here for you :wink:
Hi Max. Can you please help me? Not seeing even half of my google reviews (I should have 35). Thanks!
Mike
Hi @Michael_Shorman, I’m already looking into this! :eyes:
Hey Mike, everything’s sorted now, could you please check? :slight_smile:
Looks good. What was up with it? Happy Thanksgiving!!
Happy Thanksgiving, indeed, Mike!
Unfortunately, there was a technical glitch which we resolved on our end :slight_smile:
I hope no issues will ever come up for you, but we’re always here for you to help or just chat :))
