Dropdown of Locations/Offices/Schools
Dropdown function instead of listing all the different locations so they can easily be searchable as well.
Hi there @user10753 :wave:
A huge thank you for sharing your idea with us!
Do I understand you correctly that you’d like to have an app similar to our Store Locator app, but for offices/schools and with the dropdown option?
If I misunderstood you, please describe your use case in more detail :slightly_smiling_face:
Yes it’s similar to the store location app however I don’t need to showcase the specific locations where our organizations are found. Just need a dropdown wherein they can search for the location/school they are looking to see if our organization is available in said school/area.
Got it, thanks!
We’ll try to consider your suggestion in our future updates. We’ll keep you posted in this thread :slightly_smiling_face:
