Drill Down Menu e.g.(Year/Make/Model)
Over the course of my 18 year eCommerce design career this is not only one of the most requested but also most beneficial for many industries that require certain specification like automotive Year/Make/Model to get to a result. A drill down menu with customizable fields and finalizing path link from selections would be an amazing addition to Elfsight apps.
Thank You,
Shaun
Hi Shaun, thanks a lot for sharing your idea with the community! :+1:t2:
I see what you mean, an extended drop-down menu could be really helpful. One question, though: do you need the drill-down is some specific Elfsight widgets, or do you see it as a separate widget?
It would be great if you could share your use case so I better understand how you’d like to use this feature :slight_smile:
Thank you for your help!
