Customizable General Survey Widget
I’m looking for a flexible and fully customizable survey widget that allows users to create surveys of any kind for various purposes, whether it’s gathering opinions, conducting research, or asking general questions about different topics.
Widget Requirements:
  1. Editable Surveys:
  • Users should be able to edit the questions and answer options freely, without any technical knowledge. This includes:
    • Creating both open-ended and closed-ended questions.
    • Adding custom options for the questions.
    • Defining question types (e.g., Yes/No, multiple choice, 1-5 scale, etc.).
  1. Variety of Question Types:
  • The widget should support different types of questions, such as:
    • Multiple-choice questions.
    • Open text responses.
    • Rating scales (e.g., “How satisfied are you with…?”).
    • Yes/No choices.
    • Numerical value choices (e.g., “Rate from 1 to 10…”).
  1. User-Friendly Interface:
  • The interface should be intuitive so that users can create surveys easily. This includes an option to add, remove, and reorder questions and answer options with no hassle.
  1. Customizable Design:
  • The widget should have customization options to fit various websites or branding (colors, fonts, size, style, etc.).
  1. Real-Time Results:
  • There should be a system to view survey results in real-time, with data organized into charts, tables, or downloadable reports.
  1. Data Storage & Export:
  • Survey results should be automatically saved to a database or exportable to Google Sheets, or other file formats (CSV, Excel).
  1. Survey Publication Feature:
  • Once the survey is ready, the widget should be easy to embed in any webpage using an embed code. There should also be an option to share direct links to the surveys via email or social media.
  1. Mobile Compatibility:
  • The widget should be fully responsive, ensuring it works seamlessly across mobile devices, tablets, and desktops.
  1. Non-Intrusive:
  • The widget should be subtle and allow users to easily close or minimize it without disrupting their browsing experience.
  1. Advanced Configuration Options:
  • It should be possible to configure the survey to only show once per visitor or limit responses by IP address if necessary.
Objective:
This widget should be suitable for offering voluntary surveys to the visitors of my website, allowing them to choose whether or not to participate based on their interest. The goal is to create a non-intrusive experience that enables them to share their opinions on various topics, enhancing interaction with my site without being forced.
Thank you for considering this request. I look forward to receiving information about the feasibility of this project and the associated costs.
Hi there, @Abel_Navarro :wave:
Many thanks for such a thorough description, that’s much appreciated!
Our Form Builder widget has most of the features you’ve listed, and I see that you’ve started using it. Does it meet your case or some important features for you are missing there?
