Create a credit card payoff calculator- nper function will be required
I would like to create a credit card payoff calculator
Hi there and welcome to the Community, @James_Willits :waving_hand:
I’ve checked your Credit Card payoff widget and see that you’ve added the fields and calculations. Do I get it right all the fields and calculations are correct and you need help with formula creation for these calculations?
Hello Max,
I appreciate you following up. Since the calculator doesn’t accept the nper function, I had to experiment with multiple ways to get it to work. It seems to work ok now.
That’s great, I am happy to know you’ve managed to set up the widget the way you need.
If any questions come up in the future, feel free to contact us here. We’ll be more than happy to help :wink:
By the way, we’d like to invite you to participate in our new contest, where you can win a 3-month extension for your subscription - April Contest: What’s Your Top Widget Feature? Tell us and win 3 MONTHS FREE!:wrapped_gift:
