Finance payments payable in advance
Many lease and rental contracts can be paid either in advance or in arrears. eg monthly in advance or monthly in arrears. Last time I looked, monthly, quarterly or annually in advance were not available. Can you please fix - it can be done in excel, on an HP12C and most other financial calculators Thank you! :blush:
Hi there, @Ron_Wiber :waving_hand:
You’d like to let your clients make payments directly through the widget, right? Is, we’re currently working on adding the Stripe integration to the Calculator. Please upvote this idea to get notified about the feature release - An option to add payment button
However, if I misunderstood your idea, please describe it in more detail :slightly_smiling_face:
No. In any asset finance calculation, and where we want to solve for payment, we need the following: Cost price. Term. Number of payments (payable monthly or quarterly etc). Interest rate. State if payments to be made in ADVANCE or ARREARS. Your calculators, when I last looked, don’t give the option of paying in ADVANCE. Solving for ADVANCE payments is available in Excel, HP12C, Sharp, Spreadsheet Converter etc etc. Please advise. Need an agent, not a chatbot.
Hi there, @RON_WIBER1 :waving_hand:
Thanks for clarification!
Although we don’t have ready-made templates with advance payments fields, you can manually add them to your widget.
For example, you can create a Choice field to select Advance or Arrears payments and assign separate values to each option. Based on the option selected, its value will be pulled to your formula:
Could you please test it out and let me know if it works for your needs?
If you’re struggling with the formula creation, you can enter a prompt and the AI Calculator Generator will create a widget based on your description:
You can also check our guide explaining how to work with formulas - Working with Formulas in Calculator widget - Elfsight Help Center
Looks great. Thanks. I will look and do what you say, and get back to you.
Tx
RW
