Conditional Redirects after Submit
Hi Elfsight-Team, it would be very helpful to redirect to different urls after the user submits. This way, depending on the user’s selection, one could users to a specific url linked to a CRM pipeline.
Hi there, @user27118 and welcome aboard :waving_hand:
Great idea, thanks for sharing! We’ll try to think about it in the future updates, especially if more users support this request.
In the meantime, could you please describe the conditions you’d like to set and specify the links that should be used? I’ll be happy to check with the devs if there is a custom solution :slightly_smiling_face:
Hi Max, thank you for your very quick reply :flexed_biceps: :raising_hands:
I would like to set the Conditional Logic depending on the user input from a Dropdown field (but potentially it could be from any input given). The Condition Logic could be set up in a similar way as the visibility conditions.
Links: for each condition one individual url. In our case, there would be about 5 different urls necessary. But: I think it would be even more flexible if the user could add n links and grow the list of conditions. :slight_smile:
Thank you for your support!
I see that you have 2 Partner Add-On dropdowns. Do you need to implement the conditional URLs only for the 1st Partner Add-On, or for the 2nd one too?
