Hey Max!
I see there might be a way to create conditional logic for the submit button, and I’d love to expand on that. What I’d like to do is send users to different URLs depending on whether a specific logic condition is triggered.
In my case, there’s only one condition that needs to redirect to a different URL—the rest should just follow the standard submit action.
Is this currently possible within Elfsight, or is there a workaround to achieve it? Here’s a link to the form I’m trying to work on https://richysmart.com/101media-preview
Thanks in advance!
Max
August 26, 2025, 12:52pm
2
Hi there and welcome aboard, @Richy_Smart
Do I get it right that if this condition is met, users should be redirected to the link A, and if not - to the link B?
Simply put, yes, that is correct!
Max
August 26, 2025, 1:40pm
4
Got it!
I’ve forwarded your request to the devs and will update you once I have any news
Max
August 27, 2025, 1:39pm
6
Hey there, @Richy_Smart
Glad to say that our devs came up with a custom solution for you:
const redirectLinks = {
3: "https://www.google.com",
4: "https://www.youtube.com",
const widgetId = YOUR_WIDGET_ID;
const watchWidget = () => {
const selector = `.elfsight-app-${widgetId}`;
const widget = document.querySelector(selector);
if (!widget) return;
const getHandleSubmit = (redirectLink) => () => {
const newWindow = window.open("", "_blank");
newWindow.location.href = redirectLink || newWindow.location.href;
const submitHandlers = Object.keys(redirectLinks).reduce((acc, key) => {
acc[key] = getHandleSubmit(redirectLinks[key]);
return acc;
let currentSubmitHandler = () => {};
const form = widget.querySelector("form");
const submitMarker = widget.querySelector([
"[class^='SubmitMessage__Container']",
if (submitMarker) {
currentSubmitHandler();
if (!form) return;
const stepsTextContent = widget.querySelector(
'[class^="FormLayout__Steps"]'
)?.textContent;
if (stepsTextContent) {
const step = stepsTextContent.match(/\d+/);
currentSubmitHandler = submitHandlers[step];
observer.observe(widget, { childList: true, subtree: true });
watchWidget();
In the 2nd line of the code, you should set the redirect link for the Submit button that appears on the 3rd step. Similarly, in the 4th line, set the link for the button that appears on the 4th step:
In the 5th line, please replace YOUR_WIDGET_ID with the ID of your widget :
Once this done, add the resulted code to the Custom JS field on the Settings tab of your widget’s settings.
Note: JS codes don’t function in the widget editor, so you’ll see the code in action on your website
Give it a shot and let me know if you like the result
PERFECT, that worked! Thanks for the quick turnaround!
I have a follow up request if possible. I have some buttons I created in the 4th step. Would it be possible to implement an override if a button is selected before the submission? For reference, I used data-values on the buttons.
const buttonRedirects = {
tier_2: "https://yahoo.com",
tier_5: "https://pizzahut.com",
tier_other: "https://apple.com"
Max
August 27, 2025, 3:10pm
8
Could you please send me a link to the page, where your widget is installed? I’ll be happy to check it for you
Yes, here you go! 101media-preview
Max
August 27, 2025, 3:29pm
10
Thanks! I’ve passed it on to the devs and will update you once the code is adjusted
Max
August 29, 2025, 6:53pm
11
Here is the final JS code for your use case:
const widgetEl = widget;
const tipLinks = {
2: "https://www.example.com/tip2",
5: "https://www.example.com/tip5",
other: "https://www.example.com/other",
const finalStep = 4;
const widgetId = /*PASS_YOUR_WIDGET_ID_HERE*/;
const widgetContainer = document.querySelector(selector);
if (!widgetContainer) return;
let redirectLink = redirectLinks[3];
let tipChousen = false;
const handleSubmit = () => {
tipChousen = false;
if (newWindow) {
const handleTipButtonClick = (value) => {
redirectLink = tipLinks[value];
const form = widgetContainer.querySelector("form");
if (!form) return;
const stepsTextContent = widgetContainer.querySelector('[class^="FormLayout__Steps"]')?.textContent;
const step = stepsTextContent.match(/\d+/) || finalStep;
const isFinalStep = step == finalStep;
if (!isFinalStep || !tipChousen) {
redirectLink = redirectLinks[step];
if (isFinalStep) {
const buttons = widgetContainer.querySelectorAll('.pay-bttn');
buttons.forEach(button => {
button.addEventListener('click', (e) => {
tipChousen = true;
const value = e.target.getAttribute('data-value');
handleTipButtonClick(value);
widgetEl.on("submit", handleSubmit);
observer.observe(widgetContainer, { childList: true, subtree: true });
watchWidget();
Please check it out and let me know if you like the result
Max:
u
Hey! I am acutally having issues with the pop-up on return/submit is repeating several time.
Max
September 1, 2025, 11:07am
13
Hi there, @Richy_Smart
Could you please elaborate on the issue you’re experiencing and provide me with a screenshot of it?
Don’t worry, I switched from submitting/returning to a popup to redirecting instead.
const url = redirectLink || tipLinks.other || window.location.href;
const delayMs = 2000; // 2 second delay before redirect
setTimeout(() => {
if (window.top) {
window.top.location.href = url; // redirect the parent/top window
} else {
window.location.href = url; // fallback, just in case
}, delayMs);
tipChosen = false; // reset for next submit
This also helped with potential pop-up blocks from the browser.
Max
September 3, 2025, 5:32pm
15
Glad to know that you’ve found a solution that works for you!
If anything else comes up, we’re always here to help
