Collect leads before printing
Hi Max or anyone else checking here. Any chance we will get to add the custom lead fields to our form before printing using the print functionality that has been added. I love the ability to fill these in before emailing the results but the same pop-up would be great after hitting print and being able to add the information for the lead directly to include on the printout. Presently out workaround is to email the form and then print from the email but that’s an extra step that doesn’t seem needed.
Hi there, @user16904 :waving_hand:
We’ve got 2 custom solutions that let you hide or blur results until the form completion:
Would it work for you if the Print and Download button will also be hidden until the form completetion instead of triggering the form on the Print/Download button click?
Also could you please share a name of your Calculator widget, where you’d like to implement this customization?
Hi Max. Thanks for getting back to me. I’ve got a couple calculators I’d like to try this on but I’m not sure if your solution would work. Ideally, the print or download buttons would pass the lead form fields that are filled in when prompted after the email button is pressed. The custom lead form fields are omitted from the download and print functions as they appear to be called after the results are compiled and only when pressing the email button.
Balance Score Calculator (if you want to peek at how our calculator works)
https://42929a72ff804952adf9d945eb8f46b2.elf.site
If the print and download buttons show immediately after the email function executed would that save these custom fields from action lead form tab? It’s simply passing a field to the print or download function. doesn’t seem like this would be too difficult to implement. Alternatively, having the option by prompting the user on a separate lead page before entering the calculator page could be a way to pass on this data. Currently these fields are only passed along via email. Another option would be to be able to include text input fields in the results section whose data would be passed to the email, print and save functions.
Any thoughts?
I see need to include the form inputs along with the calculation inputs into the downloaded/printed version.
Unfortunately, this functionality isn’t supported now, but we have this idea on the Wishlist. Feel free to upvote it - Include form info into downloaded and printed versions.
If the idea becomes popular, we might think it over in the future :slightly_smiling_face:
