Questions about Download and Print buttons in Calculator
The print and download features don’t work as expected. Was hoping for a sorta screen capture of the sliders and page as designed. Also is there
a way to add a client name (input field) to the data. The saved or printed data without customer information isn’t so helpful. Can we add form input fields to the calculator for this function that are not involved in calculations. Just passing input field to report? A firstname - lastname and contact info would be quite helpful
NOTE ON BELOW REQUEST : the existing form fields that popup when doing the email form submission would work perfectly for this function requested below. Would just need to prompt the popup before printing or downloading and add / pass this data to the printout or saved data. Still… it would be nice to have the captured sliders and form print as designed.
We incorporated a media print html button with some customized print values and static input text fields on our page and this gets us 90% of the way there as it provides almost a screen capture. Would be great to be able to do this with the print and download feature provided. We are having to print to pdf and save locally just to get the data looking how we want. There is a 3rd party Javascript screen capture to pdf that might prove helpful but it seems difficult to implement.
Hi there, @user16904 :waving_hand:
Thanks a lot for the feedback!
Currently, there is no way to pass the field values and results as a screen capture. However, we’ve added this idea to the Wishlist on your behalf - Display calculator fields and resultes as screenshot instead of text in printed and downloaded versions.
If more users support this change, it might be considered in the future.
I am not sure if it’s possible to pass the form values to the printed and downloaded versions, but I’ll discuss it with the devs and will update you once I have their response :slightly_smiling_face:
Unfortunately, there is no way to include form info into the downloaded and printed versions. I am really sorry!
We’ve added this idea to the Wishlist on your behalf - Include form info into downloaded and printed versions.
If more users support this idea, it might be considered in the future :slightly_smiling_face:
