Close button background - floating review badge
Why is the background colour on my close button blue? - how do I remove the close button background colour?
Please see the attached image.
Hi there, @Scott_Brennan and welcome to the Community :waving_hand:
This issue appears because of the conflict with the styles of your website. Could you please send me a link to the page, where the widget is installed? We’ll be happy to fix it :slightly_smiling_face:
Hi Max, thank you for your help.
The current published site is: www.migrationunity.com
The site is currently undergoing a redesign and is being edited under: https://webstages.com.au/migrationunity-e/
Once the redesign is complete, it will override the top domain.
To fix the issue, please add this code to the Custom CSS field on the Style tab of your widget’s settings:
[class*="CloseComponent__PopupCloseControlContainer-sc"],
.es-close-button {
  padding: 0 !important;
.es-close-button:not(:hover) {
  background: none !important;
We’ve also noticed you’re using the code below in the Custom CSS field:
localStorage.removeItem('Reviews.closed-elfsight-floating-badge.27d600d2-e8ac-431b-ace2-d3182b394e08');
This is a JS code and if you’re going to use it further, please remove it from the Custom CSS and to the Custom JS field :slightly_smiling_face:
Is there a way to make the floating badge disappear/close when a pop-up is opened on our website? Unfortunately, when people are completing our website enquiry form, the floating badge is in front of the form on mobile. I added a close option to the widget, but when people are completing our enquiry form and click close on the widget, it closes the full website pop-up form too, and they lose all of their text.
Hi there, @Scott_Brennan :waving_hand:
Please try to use this CSS code:
[class*="BadgeContainer__Inner-sc"] {
z-index: 9000 !important;
If it doesn’t help, please add the badge back to the mobile version (it seems to be hidden now). We’ll be happy to look into this :slightly_smiling_face:
I have added that code to the CSS, and the badge is on mobile, but when I click a CTA button on the site, and the pop-up opens, the badge is in front of the form, and when I close the badge, it also closes the pop-up form.
This is the site url for design/editing: https://webstages.com.au/migrationunity-e/
We are in the process of publishing it today/tomorrow and once finalised it will overide our current site the new url will be: https://migrationunity.com/
Got it, thanks!
We’ve fixed the issue using this CSS code:
.global-styles, #elementor-popup-modal-1157 {
  z-index: 1000000 !important;
Please check your website and let me know if it’s fine now :slightly_smiling_face:
