A simple checklist with progress bar
Hi there ![]()
Our Form Builder app should be a great option for this purpose. You can use the Choice field to create a checklist:
To display the checklist on separate pages with the progress bar, use the Multistep layout:
Please give it a try and let me know if it worked for you ![]()
