Need to create a longer form without overwhelming your visitors?
With a Multistep Layout available in the Form Builder, you can organize fields into clear sections and make the process more user-friendly
How to set it up
Enable the Multistep layout
Open your widget configurator, go to the Layout tab, and select Multistep under Form Layout options:
Customize your form pages
Once enabled, your form will be automatically divided into two pages:
Open each page and choose the elements you want to include:
Repeat the same process for the second page:
Add more pages if needed
You can create additional pages, add names, and include descriptions to make your form easier to navigate:
Your multistep form is ready! Breaking longer forms into smaller steps can help make the filling process smoother for your visitors.
Friends, was this guide helpful? Let us know in the comments
