We are loving the Chatbot. However, even when putting specific page url links in both the Q&A and block sections, the Chatbot still doesn’t give them to people looking for specific information. Would very much like the Chatbot to be able to direct people to pages that are relevant to their questions.
Would like the Chatbot to send people to specific pages on the website for more information on relevant to their questions.
Hi @Michael_Sweeney2
That’s possible, or what do you mean exactly?
I trained exactly that in the Q&A.
Hi there, @Michael_Sweeney2 ![]()
Could you please send me a link to the page where your widget is installed, or just specify its ID? I’ll be happy to look into this for you ![]()
I’ve put it in multiple Q&A, but have not had function as of yet…
Thank you so much, @Michael_Sweeney2 ![]()
I’ve shared it with the devs and will let you know once I have their response ![]()
@Michael_Sweeney2 We’ve added this point to your instruction and now everything should be working fine: If the user’s question exactly matches or closely resembles a “Question” entry from the knowledge base, provide the corresponding “Answer” verbatim from the knowledge base.
Please check it out and let me know if it worked for you ![]()
Thank you. That is what we currently have in place–hopefully it will work now.
Is there a way to teach the AI Chatbot to direct people to pages for more information that is not specific to verbiage that we put into the Q&A section?
I guess it’s possible if you reflect your idea in Instructions clearly.
Are you going to use the same link, or it will vary depending on the case?
