Change background and text color of past events
I want to change the color of the text and also the background of the past events. Past events should stand out from upcoming ones.
I use the List layout
I’ve discussed it with the devs, and, unfortunately, there is no way to change the background and text color for the List layout at the moment.
I’ve moved this idea to the Wishlist and if it gets more votes, we’ll try to consider it in the future :slightly_smiling_face:
Friends, great news: this feature request is in the Design stage now!
We’ll keep you updated on the progress :slight_smile:
Status Update: the feature moved to the Development stage :tada:
Hey everyone!
Great news — we’ve added an option to change the background color of the past events :tada:
To change the background, click on the Customize Theme button on the Theme tab, select Event and use Past Event Background Color option
Find more new features in this post: Event Calendar: Change color of each widget element, font, size settings and more! 🚀
