Ability to change past events overall settings
Hey,
If the Past Events layout could be changed to be different to the current events. For example the current events would be in Grid format, and the Past events could be in List format. The same goes with the background colour. If the Past could differ from the Current events, but be an overall setting, not an individual event setting.
Also, not sure if this is possible, but I could direct traffic specifically to Past events somehow. i.e. in Squarespace, if the Past Events were set up in a different section to the Current events, then I could anchor point to them but as they are all one widget, I am unable to do that.
Thanks :slightly_smiling_face:
Greetings and welcome to the Community, @Tara_Edwards :waving_hand:
Unfortunately, the features you’ve mentioned are not supported at the moment. However, I agree that it would be awesome to have separate settings for the Past events.
We’ll try to consider this idea in the future, especially if more users upvote it.
Thank you so much for the feedback :slightly_smiling_face:
