Calorie Calculator! 🍏
Using the ‘Harris Benedict Equation’, a widget which calculates your overall daily calories needs and macronutrient breakdown, based on customer details (e.g. height, weight, age, activity level).
Hello there @David_Cooney1 :wave:
Great news - we have a Calculator app that should a perfect option for you! You can use the AI Generator feature and it will build a calculator according to your request.
Give it a try and let me know if it worked for you :slightly_smiling_face:
OK, brill! I’ll have a look! :slight_smile:
