Calendar's iCalendar (iCal) address
I need the calendar’s iCalendar (iCal) address.*
Hi @Barbara_Gainwell, welcome to our community! :smiling_face:
Do you mean you’d want your visitors to add events to their iCal, or would you like to to connect a widget to your iCal to add events from there?
Thank you for the details!
Good morning, I have to add the widget, but my widget has a “Get Tickets” button that does nothing when the person clicks it. I want to know how to activate the Get Tickets buttons. Is it possible to make the button active.
Got it, thanks!
You just need to add the needed link to this button in your widget’s settings. Please go to your Event Calendar widget → choose the event → scroll down to the Button section → add the link you need:
Let me know if it helped :slight_smile:
No, I added the widget and the get tickets button on your widget is not active.
Hi @Barbara_Gainwell!
I’ve checked your widget one more time and see that the link was not added to the button. Let me show you how you can set it :slight_smile:
I’ve recorded a screencast of your widget’s settings (the event is inactive as its end date was set to August, 8) and showed where you should add a link:
