Brizy Website Builder: A Great No-Coding Solution
Hi Elfsighters! :star_struck:
Are there any Brizy users here? If so, I bet you’d confirm that this is a very user-friendly website builder, allowing you to create a website in a jiffy. You don’t have to know any code, everything is really easy and intuitive!
On top of that, our widgets work perfectly fine there, all you need to do is just add the installation code and see your widget up and running in a second :raised_hands:t2:
So, how do I install my widget?
  • Open your Brizy project.
  • Find ‘Add Elements’ button.
  • Go to ‘Content’ section and find ‘Element’.
  • Drag and drop it on your page.
  • Click on the ‘Embed’ element and add your Elfsight widget’s installation code.
  • Voila! See your widget on your website!
It’ll be nice to hear your tips or hacks for using this platform! Or, if you’re on the hunt for the best solution, I recommend giving this one a try :slight_smile:
Any questions? Drop them below! :arrow_heading_down:
