Is there anyway I can code in a hover effect on a product slideshow? The initial one I have created, ‘product images’ is for the main product page, which I would like to show a coloured circle behind the product on hover. I will be creating more static product widgets for product categories which I would like to display the green circle behind when it is selected.
This is the sort of idea I have. On their main page there is a carousel where a green circle appears on hover. If you click through they then have thumbnail product images with the same effect but the green circle also stays when selected.
I see that the logos in your widget are quite wide, and you are using colored background. So, I guess it will be hard to add a green circle matching the height of this container:
It would be for the other widget carousel on my account, ‘product slider product page’. I just created it as a test run to see if it was possible so it does not include everything yet. I am also yet to create the static ones which I am hoping to use on various other product pages. Would this be code that I can copy into other widgets when needed?
I think this one would be fine? I’m happy for the padding to be increased if needed.
Sorry, just one last thing I was hoping you could advise on. So if I use the same menu with say 4 ‘logos’ (product images) corresponding to 4 separate product pages, if there a way of making the green circle remain on the selected image?
Yes, it’s possible, but the widget should be installed on these pages first. Once it’s done, please send me a link to your website, and we’ll be happy to apply this customization
