Auto updation of URL upon applying filters
From the UI, when I apply a filter and share the URL with someone. The URL does not update to the applied filter. Instead it opens the standard UI page. Why doesn’t the UI update when a filter is applied. How can this be fixed?
Anchor links won’t help in my scenario. I want standard screen (no filters) to show up by default. However, when I share the calendar with specific group of learners, to share sessions that are relevant to them, I want to apply the filter and then share the link. So that they see only the sessions that are relevant to them.
I have the filters created. However, the URL does not automatically update when a filter is applied. I have many stakeholders who share these URLs regularly. Auto-updating URLs when a filter is applied, is what I am looking for.
Hi there, @user10588 :waving_hand:
Unfortunately, this feature isn’t supported by default, but I’ll be happy to check if there is a custom solution :slightly_smiling_face:
Could you just share a link to the page where your widget is installed?
Sure - https://sandbox.elfsightcdn.com/87943e7a-5af7-464b-875e-5a05d9d34234
Hi @user10588 :waving_hand:
Thanks for sharing the sandbox link! However, I’ve meant a link to the page on your website, where it’s installed. Could you please provide me with it?
