Audio player widget enquiry
Hi! I’ve featured the audio widget on every page on my website; however, I’m encountering some difficulties. When directing to another tab on the site, the player begins again rather than continuing fluidly.
Is there a way to have the audio player continue playing background music without interruption? Is this an option for premium users?
The website will be launching September 22nd, and is being organised for fundraisers. Any guidance I could receive before this date would be so helpful.
Thank you so much.
Gemma-Karma
Hi there, @Gemma-Karma :wave:
You can do this using the Save Playing Track and Progress on the Player tab of your widget’s settings:
Check it out and let me know if it worked :wink:
Hi Max
Thank you so much! It’s fixed the primary issue, but unfortunately it seems to have caused other issues: delaying, the player disappearing when clicked.
I’ll try to find a resolve before I consider using another player
Kind regards
Gemma-Karma
Hi, @Gemma-Karma :wave:
I’ve tried to check the issue, but it seems that you’ve removed the widgets from your website. Could you please bring them back or install them on a test page?
I’ll be delighted to look into this for you :slightly_smiling_face:
