Allow FAQ content to be copied and paste
I am unable to copy and paste content in elfsight FAQ. Is there any way to enable this?
Hi there, @Jasper_Phua :waving_hand:
Sorry about this inconvenience!
We’ve fixed the issue with this code added to the Custom CSS section on the Appearance tab of your widget’s settings:
.global-styles,
#main * {
 user-select: auto !important;
Please check it out and let me know if everything is fine now :wink:
works perfect, thanks Max. Also is there any way I can adjust the white space above the FAQ search bar?
Sure! You can change the spacing between the title and the search bar using this CSS code:
.es-widget-title {
    margin-bottom: 30px;
Feel free to adjust the margin-bottom value to your liking and let me know if it helped :wink:
