AliExpress Reviews
  • ** AliExpress Reviews**
    why it can’t load reviews from ali express
Hi @Amr, and welcome to our community forum! :hugs:
I’ve altered the link in your widget a bit, so now everything works fine :slight_smile:
Could you please check and let me know if you’re good?
Thank you it works fine :heart:
Awesome, I wish you just a great user experience with the widget!
And we’re always here should any help is needed :slight_smile:
Have a great and productive week!
Can I change the Author Name?
Author Name is ALi Express Shopper I cant use it?
I tried to get another review widget it also didn’t work
what is the problem?
please tell me the right way to use ?
I have many things to do with the wedgets
@Amr, I’m afraid there is no option to change the author name, but you can not show the name at all:
As for your second question, could you please make sure that the link you’re trying to add looks like this one: https://aliexpress.com/item/32962473198.html ?
This is the only format supported in the widget, so please make sure your link fit the requirement.
Please let me know if it worked :slight_smile:
I use the link like that, but the end is not .html
this is the product url like the one you fixed
I get it thank you for your help
there is a big problem in this widget !!!
that write a review button takes the customer to aliexpress page
it must be linked to my website review
Yes, with the way our app works, this button leads to Aliexpress directly, so your customers can leave their review to your product there.
This new review will appear in your widget within 48 hours, so no worries at all :pray:t2:
how no worries ?
I’m a drop shipping not amazon reseller
this works with amazon resellers FBA or any method like that
but not drop shippers
Oh, I totally understand your point, but I’m afraid there is no way to change the way our widget works, I’m really sorry :frowning:
At the moment your customers can leave their reviews only on the platform directly. I wish I had another solution for your here :pensive:
We have another app which althought doesn’t let your customers leave there reviews on your website, but lets you add any reviews manally: Tesimonials Slider
Maybe this one could suit you better?
