Looking to change the default texts in your AI Chatbot? You can edit button labels, form fields, notifications, error messages, and other text elements directly from the widget settings ![]()
To find this option, go to Settings → Language & Region → Edit Text:
There you’ll find a list of all customizable text elements. Just click on any of them and replace the default wording with your own:
This is a quick way to adjust the chatbot’s wording and make it better match your website ![]()
Was this guide helpful? Let us know in the comments
