Adding Multi-level Dropdown Menu to Squarespace
To add Multi-level dropdown menu to Squarespace like this
#1. Install Code
#1.1. First, you can add a Dropdown Menu, something like this
#1.2. Next, hover on dropdown > Click Gear icon
See URL Slug. We will have /sm-pages
#1.3. Use this code to Code Injection > Footer
  • If you use Personal/Basic Plan and your plan doesn’t support Injection, see #3.1
window.MultiLevelDropdownConfig = {
  enabled: true,
  matchBy: "text",
  dropdowns: [
      folderId: "/sm-pages",
      submenuDirection: "right",
      matchBy: "text",
      parents: [
        "Item 01",
        "Item 10",
        "Item 20",
        "Item 30"
<script src="https://code.beaverhero.com/header/0626c25v1multileveldropdown.js"></script>
#1.4. Update options in Line 06 to Line 18 (explain below)
dropdowns: [
    matchBy: "text",
    parents: [
      "Item 01",
      "Item 10",
      "Item 20",
      "Item 30"
This option means
  • change Item 01, Item 10, Item 20, Item 30 to main level and items under them to second level
  • Line 08: /sm-pages is URLSlug in step #1.2
  • like this
#1.5. In case you want to add 2 Multi-Level Dropdown Menus, for example this dropdown
We will have code like this
  • Note: /reuse-pages-1 is URL Slug of this dropdown menu
dropdowns: [
    matchBy: "text",
    parents: [
      "Item 01",
      "Item 10",
      "Item 20",
      "Item 30"
    folderId: "/reuse-pages-1",
    matchBy: "text",
    parents: [
      "Gallery Form",
      "Custom Menu"
#2. Customize
#2.1. To remove shadow around second level menu, use this code to Custom CSS
div.mld-submenu {
    box-shadow: none !important;
#3. Other
#3.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can edit Site Footer
Choose Markdown
Add this code into Markdown
  enabled: true,
  matchBy: "text",
  dropdowns: [
      matchBy: "text",
      parents: [
        "Item 01",
        "Item 10",
        "Item 20",
        "Item 30"
