To add a Dropdown Menu in Squarespace, you can follow these.
A. Single Dropdown Menu
#1. First, click on the Plus icon (+) in Not Linked or Main Navigation
#2. Next, scroll down to the bottom and choose Dropdown
#3. Then, click ADD PAGE below the Dropdown to make your Dropdown menu items
B. Multi Columns Dropdown Menu
#1. First, you need to know this
#2. Use this code to Custom CSS box
div.header-nav-item:nth-child(2)>div {
column-count: 2;
column-gap: 5px;
#3. Result
C. Multi Levels Dropdown Menu
You can use Nested Menu Plugin
