Description
- automatically adding Shop Categories to Header Dropdown menu
- view demo – password: abc
#1.1. First, find Store Page URL
In my example, we will have: /storedemo
#1.2. Create a Dropdown to Main Navigation
Dropdown will have
- Name: you can enter anything what you want
- URL Slug: use format: /dropdown-{store page url slug} – In my example, it will be: /dropdown-storedemo
#1.3. Use this code to Code Injection > Footer
- If you use Personal/Basic Plan and your plan doesn’t support Injection, see #3.1
<!-- 07.26c07v8 Shop Categories to Header Dropdown -->
window.ShopCategoriesConfig = {
dropdownPrefix: "/dropdown-",
submenuDirection: "right",
maxDepth: 0,
hideArrowOnMobile: true,
openFolderOnTitleClick: false
<script src="https://code.beaverhero.com/store/0726c07v8storecategoriesdropdownmenu.js"></script>
#2.1. On mobile, by default, if users click Dropdown Title it will open Store Page Panel with dropdown format like this
But if you want to make it open Store page on click title, you can change Line 08
to
openFolderOnTitleClick: true
#2.2. To enable right arrow next to Dropdown Title on Mobile, you can change line 07
hideArrowOnMobile: false,
to
#3.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can edit Site Footer
Add a Markdown Block
Add this code into Markdown Block
maxDepth: 0,
