Add WOMO to Allinone Reviews
Hi
It would be great if WOMO can be added to Allinone Reviews. It is used a lot in Australia.
@Edwin thank you for your suggestion, we’ll try to consider it in our future updates!
Support WOM reviews in the widget.
Hello there and welcome aboard @user13302 :wave:
Thanks a bunch for your feedback!
Such a request is already available in the Wishlist, and I’ve moved your comment there too. We’ll keep you posted here in case of any changes :slightly_smiling_face:
We would love to have wordofmouth.com.au (WOMO) reviews in the reviews widget. It is one of Australia’s largest and oldest sites for service reviews
Instead of the custom option would love to have it direct
Hi there, @user20695 :wave:
Many thanks for sharing your feedback!
We’ll try to think about this opportunity in the future, especially if more users upvote this idea :slightly_smiling_face:
