Please add vitals.com physician profile reviews as a review source.
Greetings @Viraj_Tirmal and welcome to the Community ![]()
Thanks for adding your idea to the Wishlist!
We’ll try to consider implementation of this source in the future. All the updates will be posted here ![]()
