Add reviews from vagaro.com
I’d like to have vagaro.com as a source to pull reviews from.
Hi there, @Amy3 and welcome aboard :waving_hand:
Thanks for sharing your idea with us! If this request gets more votes, we’ll try to consider it in the future :slightly_smiling_face:
As a workaround, you can use a Custom Source option in our All-in-One Reviews app and add the needed reviews manually. Feel free to check it out:
I would love to see the option to pull reviews directly from vagaro.com. Many salons, spas, and beauty professionals use Vagaro as their main booking platform, and a lot of our client reviews live there instead of Google or Yelp. Being able to display Vagaro reviews through the All-in-One Reviews widget would make it much easier to showcase client feedback on our websites without manually copying reviews or directing clients to multiple places.
Hi there, @Lauren_K :waving_hand:
Thanks a lot for the feedback!
We already have a request for this source and I’ve merged comment with it. Currently, the vagaro.com source isn’t supported by our review provider, this is why it’s impossible to implement it.
However, we’ll keep tabs on it and if anything changes, we’ll update you here right away :slightly_smiling_face:
