Please add IDR (Indonesia Rupiah) Currency on calculator. THank you.
Hi there @monette_medina ![]()
A huge thank you for adding your idea to the Wishlist!
We’ll try to consider implementation of the IDR currency in the future. All the updates will be posted here ![]()
As a workaround, you can use custom suffix option for your case:
Choose Number and set your custom suffix
