Add GDPR Check up Data Privacy beforе load Google Maps
Users in the EU must actively consent before map data from Google Maps is loaded.
It would be important that the relevant parts of the widget are only loaded after the user has confirmed/clicked on a corresponding notification.
According to the EU GDPR, data storage outside the EU is prohibited, and Google stores data on servers in the US.
The Store Locator uses Stadiamaps / Openstreetmap, but if data is sent outside the EU, this also affects this widget.
You can circumvent this without consent if the server containing the tile data is located in the EU.
@Sina, many thanks for the detailed request! I’ve shared it with the team so that they take it under consideration. All the updates will be posted here :slight_smile:
