Instead of having only 1 product in my image choice, I have the possibility to select an amount (2, 3 or 10) of image choices that I want.
Hi there, @Adrien_GRABOWSKI ![]()
You’d like to let users pick only 1 image option, right? If this is the case, just disable the Multiple Selection option in the settings of the Image Choice field:
However, if it’s not what you meant, please describe your idea in more detail ![]()
