Add a discount to a specific position
I would like to show that there is currently a discount on certain items in the list.
The old price should be crossed out. Badge: 50% (for example) and then the new price.
Thank you! :blush:
Hi there, @zuno.tax :wave:
I’ve checked your widget and see that you’ve already found a solution, which looks great:
If you’d like to make some further adjustments, please let us know. We’ll be happy to help :wink:
Hi there :slight_smile:
Yes I’m kind of happy with the solution :slight_smile: and yes I have another topic: I wand to chance the stroke color, if an element is chosen. And Can I chance the icon? I made a prototype in Figma (screenshot) - that would be super nice.
Thank you
Yeah, we’ll try to do that!
I’ve forwarded your request to the devs and will get back to you once the solution is ready :wink:
Hi @zuno.tax :wave:
Here is a solution from the dev team:
[class*="choice-option__RadioControl-sc"]:after,
[class*="image-option-button__RadioButton-sc"]:after {
  display: none !important;
[class*="choice-option__Overlay-sc"],
[class*="image-option-button__Overlay-sc"] {
   background: none !important;
[class*="choice-option__RadioControl-sc"],
[class*="image-option-button__RadioButton-sc"] {
  background-color: transparent !important;
  border: none !important;
  background-image: url('https://files.elfsightcdn.com/10f57fcd-29bb-4da4-9c09-61ea49a5bf6e/456ad39f-4654-4383-84cd-77b6af86a8e8/check3.png');
  background-size: 100%;
[type="radio"]:checked + * [class*="choice-option__RadioControl-sc"],
[type="radio"]:checked + * [class*="image-option-button__RadioButton-sc"] {
  background-image: url('https://files.elfsightcdn.com/10f57fcd-29bb-4da4-9c09-61ea49a5bf6e/ba5e93fa-1bd5-43cf-bf11-7b722450f896/check2.png');
[class*="image-option__Item-sc"]:has([type="radio"]:checked) {
  border: 1px solid #7e7cf3;
Please add this code to the Custom CSS field on the Settings tab of your widget’s settings and let me know if you like the result :wink:
Hello Max!
wow, that’s amazing! It worked perfectly! Thank you and the dev team so much for your help!
I think it looks great!
Happy to hear that!
If any assistance is needed in the future, we’re always here to help you :wink:
