A mix of short and long descriptions doesn't work
When description gets a line break(s), the additionnal lines do not push design downwards as usual and expected, but it pushes the image upwards, thus cutting off the top of this image.
This must be an oversight(?), as this makes it impossible to standardise images if there are a mix of short and long descriptions.
I tried finding a CSS workaround, but couldn’t.
Hi @Kristian_Frost welcome to community :grinning_face:
Would you share the link to the widget?
Hi,
Yes.
On Elfsight:
https://dash.elfsight.com/widget/9295011a-ff87-4e74-8fc7-bf7e74169e49
WWW:
https://www.sif-trøjen.dk
I’ve set this CSS to counter it somewhat:
.eapp-photo-gallery-thumbnails-image {
margin-top: 20px !important;
But this shouln’t be necessary. This makes it look okay on computers and tablets in Landscape orientation. But it’s impossible to make it work/look nice on Mobile/Portait orientation without having a huge gap. Try flicking through the season 2022/2023.
Cheers :smiley:
Hi @Kristian_Frost
Thanks for sharing. I took a look. You’re right, it doesn’t look good.
But I did notice something with the padding.
If I deselect it, it works without the img margin.
grafik
grafik
Unfortunately, I can’t see it on your dashboard.
You can share the widget alone here. Install Code Page and then Share Link
Hi there, @Kristian_Frost and welcome to the Community :waving_hand:
I’ve checked your widget and there is no cropping issue on my end now (even without using your CSS code).
Could you please confirm if everything is fine on your end now?
