2 way link for ICS files
Please add 2 way link for .ICS links.
I need to sync my website’s calendar with VRBO, Airbnb and Booking.com
The current Google Maps integration i use now is…buggy, and ugly.
Hi @Jimmy_Wilkins :wave:
Do I understand correctly that you’d like to import events to the widget not only from your iCalendar. but form the VRBO, Airbnb and Booking.com sources at the same time?
Hello, yes that’s it :wink:
Got it, thanks!
We see how useful this option might be for our users, so we’ll try our best to consider it for thet future updates.
I’ll keep you posted here :wink:
Merci. :wink:
iCalendar (iCal / ICS) is extremely useful for a minimal maintenance/2-way calendar for short-term rentals. This would be AWESOME! :folded_hands:
