Integration with Outlook Calendar to synchronize slots and add bookings to it
Integration with Outlook Calendar to synchronize slots and add bookings to it.
Only supporting Google Calendar killed it for me.
Office 365 (Outlook) support would be appriciated.
Hi there @Patrick_Prziborsky :wave:
I am really sorry that the Outlook integration isn’t available at the moment. The good news is that we already have such an idea in the Wishlist, and I’ve dropped your comment there too :slightly_smiling_face:
If more users support the Outlook integration, we’ll try to take it under consideration. All the updates will be posted here.
Hoping to speed this update along by adding that I also wasn’t able to use this feature due to limited integration options.
Hi @Michael12 :wave:
Many thanks for upvoting this request!
Let’s hope the devs will be able to consider this integration in the future and I’ll make sure to update you here in case of any changes :slightly_smiling_face:
Please add an outlook calendar or microsoft exchange integration.
Hi there, @Robert_Munster :wave:
This idea already exists on the Wishlist, and I’ve merged your comment with the original request.
Thanks a bunch for the feedback and yes, welcome to the Community :slightly_smiling_face:
Please add Outlook Integration to Appointment Booking.
Hey there, @user1064 :waving_hand:
Many thanks for the feedback!
This idea is already on the Wishlist. I’ve merged your comment with the existing request, where we’ll keep you updated :slightly_smiling_face:
Yeah for me - lovely idea but not useful until linked into Outlook and/or calendarly
Hey there, @Geoff_Robinson and welcome aboard :waving_hand:
Thanks for upvoting the idea! Let’s hope this idea gets more traction with the Community and the devs will be able to consider it.
If any news comes up, we’ll update you here right away :slightly_smiling_face:
Really Really Really would appreciate Outlook synchronization for the Appointment Booking App. Thank you Max!
Thanks a lot for your comment, @user30498! Happy to welcome you to our community :hugs:
I’m looking forward to connecting to the Outlook 365 calendar. In the meantime, a workaround would be helpful. Using an ICS link, you can load your Outlook calendar into a Google Calendar. It will then appear alongside other calendars. It would be great if the Elfsight module could then allow you to choose from Google Calendars, instead of automatically using the default calendar.
Hi there and welcome to the Community, @Tom-nl :waving_hand:
Add the Outlook Calendar to the Google Calendar could be a great temporary solution, but, unfortunately, it won’t work.
As you’ve correctly mentioned, the imported calendar will appear in the Other Calendars section. Basically, other calendars are calendars you’re subscribed to but do not own. They don’t appear when using Google Calendar integration in Appointment Booking app, because you don’t have a control over the appointments in this calendar.
I understand, that in this case the other calendar belongs to you, but since it’s imported from the Outlook, it won’t be available in the Google Calendar integration.
I hope this explains things.
Thus, unfortunately, we don’t have a workaround at the moment. However, we totally understand that the Outlook integration would be really helpful for many users.
Let’s hope the devs will be able to consider it in the future updates. We’ll keep you in the loop :slightly_smiling_face:
Patrick, if you don’t mind me asking - what do you use instead?
