2 and 3 column section builder
So you can embed 2 or 3 different widgets in one section. My use case is your calendars. You separate your calendar views into single instances and you can’t switch a view dynamically within one calendar.
Solution would be to lay the calendar view options of Month and upcoming event grid style side by side. If you could have a template with 2 or 3 columns, so any 2 or 3 widgets can be positioned side by side. Users don’t want to scroll or click if they don’t have to.
Actually if you could also create a 2 and 3 column section builder with customization to put in a widget, text, image or buttons. That would dynamically give us designers creative flexibility and minimizing pages or scrolling too much to see all content.
Thank you​:blush:
Hi there, @Michelle_Clune :waving_hand:
Thanks for sharing your idea!
Could you please send me a link to the page, where you’d like to place your calendars in 3 columns? I’ll gladly check if it’s possible to achieve :slightly_smiling_face:
Most likely 2 columns at this point. I’ll get you an image soon.
What about the other idea whether it is 2 or 3 columns. You can display widgets, but also mix in images, text, or buttons in any of the columns.
Thank you
Got it! Most likely it’s possible to display 2 widget nearby. However, to check things, we’ll still need a link to the page, where you’d like to add a widget.
As for adding the builder to display the content in multiple columns, unfortunately, we won’t be able to incorporate this idea.
The functionality you’ve described, sounds just like a section in the website builder, where you can place different content the way need, which goes beyond our general widget concept.
Hope this clears things up :slightly_smiling_face:
