Write a review button position option
The only option to position the “write a review” button in different places is to force it with CSS which it works. It would be better to offer a layout option for the button it self, so that it can be easily moved around.
Thanks
Hi @Alessandro_Santese :wave:
Yeah, I agree that it would be cool to adjust the button’s position without using CSS codes. We’ll try to take your idea under consideration and I’ll make sure to update you here in case of any news :slightly_smiling_face:
Many thanks for adding your request and yes, welcome to the Community!
Thank you @Max
You are always welcome :wink:
Hi @Alessandro_Santese, thanks for adding your idea to our Wishlist!
I’ve been considering this possibility, and I’m curious: do you maybe have any ideas for the Write a review button positions? We’ll be happy to consider your thoughts :blush:
Hi Helga,
I think it might make sense to offer 6 positions available:
  • above left, middle and right
  • below left, middle and right
To me it would make sense to always have it below in the centre but it will be different for others.
Thanks
Can you put down write a review button at the button of the widget where it says to view more.
It does make sense, many thanks for the reply, @Alessandro_Santese!
