( https://starfleetUpTo.date/Screenshot_2023-09-30_21-03-52.png ) so why not as first meassure put “write a review” more to the left to increase display space, like furthermore to define an overflow:visible exception css property fo that list… I remember I achieved sth. similar already one time… a nested into overflow hidden overlapping visibly… I could figure it out once more how it works, but I don’t know yet, if you really can afford me… he he he… ;-P))))
Hello there @fELIx_Check ![]()
We are so happy to see you as a part of our Community, welcome!
I’ll check things with our dev team and get back to you a bit later ![]()
Please add this code to the Custom CSS field on the Appearance tab and let me know if it helped ![]()
.global-styles,
.es-header-container {
flex-direction: column;
align-items: flex-start;
If the solution works, do I understand correctly, that you’d like to switch your Google Reviews subscription to All-in-One Reviews Basic monthly plan?
Hi Max… many thnaks… indeed solved the issue!
It’s my pleasure!
You are always welcome ![]()
