Working “Integrations”
Hi :waving_hand:t5: @Max and Community :sparkles:,
With thanks,
mw :man_technologist:t5: :sparkles:
Hi there, @iammasterweb :waving_hand:
All integrations available in the widget should be working fine now. If you’re experiencing issues with any integration, please send me a track link you’re trying to use. I’ll be happy to check things :slightly_smiling_face:
Thank you Max.
Will check it out.
