Widget for individual podcast episode
Is there a way to create a widget for an individual podcast episode instead of displaying all the episodes from an entire show? If not, can I request that feature?
Greetings @user8313 :wave:
You can find the item blocks in your XML file (Tubonge Tax) and remove the blocks for the podcast episodes you don’t want to display:
This should allow you to only add one episode to the widget. If you need our help with that, please let me know which episode you need to use. Our devs will be happy to help :slightly_smiling_face:
