Widget flickering issue on Framer
hi @Max, not sure if this is related but I seem to having flickering and resizing issues in Framer on load. Are you aware of this one?
Hi there, @Marley662 :waving_hand:
This issue occurs because of the iframes used on the Framer platform. To fix it, please try to reinstall the widget avoiding iframes following the steps described in this article: Installing Elfsight widget on Framer avoiding iFrame - Elfsight Help Center
Give it a try and let me know if it helped :slightly_smiling_face:
Hi Max, that was a huge help. Flickering is gone which is great for any visitors, but now the backend experience is getting a little clunky! After a hard refresh it usually adjusts back, but as I’m editing other areas of the page it seems to revert back into this exploded kind of mess.
it’s sitting within a content type field, as a component.
I’m glad to hear the flickering issue has been resolved. Thank you so much for the feedback!
We’d also like to investigate what’s causing the backend issues on your website. To identify the cause, our team will need temporary access to your website’s backend.
This article explains how you can safely share access with us: Providing Access to Your Framer Website - Elfsight Help Center
Once you’ve shared the access, just let me know and I’ll pass the details along to our dev team for further investigation :slightly_smiling_face:
