Integration with Framer
It would be great to have a direct integration with Framer, so that widgets can be installed outside of iframes and are fully responsive.
Thanks a lot for adding your suggestion, @Pete_Manning, and welcome to the community!
Do you mean that you’d like this integration to be built into each widget? Could you please share how you envision it working? Thanks a lot!
Hi,
Can’t really add anything else. The elfsight Devs are already aware of this request as is Anna from your support team. The widget does not integrate correctly with Framer. It would be great if this could work in the same way as it does with Webflow, Wix etc
