Way to remove label
Hello all! Does anyone know if there is a way to remove the before/after label all together on the Before/After slider? I can change the color/size but not get rid of the label all together?
Hi @user14293, happy to welcome you to the community! :wave:t2:
If you mean you need to remove the “Before” and “After” buttons, you can just remove these captions on the Content tab:
Let me know if it helped :slight_smile:
Thank you- that is exactly what I needed and couldn’t find!
Awesome, you’re most welcome! :hugs:
