I am new. I can’t get VRBO reviews to load. How do I fix this? I can get Airbnb to load
All in one widget
Hi there, @user30963 ![]()
I’ve tried to open the links you’ve added to the widget and they can’t be opened. For example, when I enter https://vrbo.com/en-gb/p1388793, it redirects me to the homepage.
Could you please double-check if the added sources are still available on VRBO?
Some of them are working for VRBO and some are not. I can’t see a difference.
This works Hidden Gem at Notch | Branson Cozy Getaways
This now works Walk-in at Notch | Branson Cozy Getaways
This does not work The New Branson Adventure Condo | Branson Cozy Getaways
This does not work Relaxville at Stonebridge | Branson Cozy Getaways
Does not work Fourmile Creek Lodge | Branson Cozy Getaways
Does not work Knotty Pine Retreat | Branson Cozy Getaways
There are just so many not working. It is hit or miss.
I see now, thanks for sharing the link!
I’ve forwarded this issue to the devs and will let you know once it’s fixed ![]()
I have a list of them not working. Can someone reach out to me?
I deeply apologize for the long wait!
I’ve already passed the not working sources to the dev team, and they’re doing their best to fix it as soon as possible. We’ll keep you updated!
If you have new not working sources, that you haven’t sent us before, feel free to share it here. Our devs will check them too ![]()
Apologies for the long wait!
The issue has been resolved. Please check your widgets and let me know if it’s fine now ![]()
