Troubleshooting Issues with Website Translator
When using the Website Translator widget, you might run into some translation issues.
In this article, we’ll explain common causes behind these issues and share simple solutions to fix them. Every situation is different, but with the right tweaks, smooth translations are just a few steps away!
Widget Installed Inside an Iframe
Some website builders (like Wix, GoDaddy, Google Sites) automatically wrap content in iframes, which can go unnoticed.
Iframes create isolated containers, restricting interaction between the widget and other content. This means the widget can’t access content outside the iframe, causing translation issues.
The good news is that placing the Website Translator widget outside the iframe often solves this problem.
Fixing Iframe Installation Issues
On certain website builders, like Wix and GoDaddy, you can install the widget outside of the iframe container to avoid translation problems.
To help you get it right, we’ve put together detailed guides for these platforms:
Unfortunately, this workaround doesn’t apply to Google Sites. :pensive_face:
The iframe structure used by Google Sites can’t be bypassed, so the Website Translator widget will still face limitations if placed inside an iframe.
Embedded Third-Party Content
If the content you want to translate is embedded in third-party apps or external containers (like widgets, plugins, or other embedded elements), the Website Translator widget won’t be able to translate that content.
This happens due to browser security, which blocks the widget from accessing content in iframes from other domains.
As a result, the widget can only translate content directly visible on the page and, unfortunately, there is no workaround for this.
Conclusion: Placing the widget outside the iframe (whenever possible) is the best way to solve translation issues.
We really hope these tips help make everything run more smoothly for you! However, if you still have any questions, just let us know in the comments. We’ll be happy to help :wink:
