Track Send Message clicks using GTM
Hello Max,
Do you have a Google Tag Manager listner for the Whatsapp widget?
I’d like to track when the user clicks on send a message and it redirects to Whatsapp.
Thanks
Hi there and welcome to the Community, @Antoine_Varraso :wave:
I’ll discuss it with the devs and will update you tomorrow :slightly_smiling_face:
Hi there, @Antoine_Varraso :wave:
Here is the solution from our devs:
const SEND_MESSAGE_EVENT = 'click-send-message-button';
const waitForElem = (selector) =>
  new Promise((resolve) => {
    if (document.querySelector(selector)) {
      return resolve(document.querySelector(selector));
        observer.disconnect();
    observer.observe(document.body, {
      childList: true,
      subtree: true,
if (dataLayer) {
  waitForElem(
    '[class*="eapps-whatsapp-chat"] [class*="MessageField__MessageButtonContainer-sc"] button'
  ).then((sendMessageBtn) => {
    sendMessageBtn.addEventListener('click', () => {
      dataLayer.push({ event: SEND_MESSAGE_EVENT });
This code should be added to the Custom JS field on the Appearance tab of your widget’s settings. Try it out and let me know if it worked :wink:
Hello @Antoine_Varraso ! Welcome to our community! :right_anger_bubble:
I see that @Max already answer your question! Let us know if it works! :wink:
Have fun in the community! :grin:
Hello Max,
Thank you.
I have the same issue with a framer website.
Can you help me out to track the whatsapp button within GTM ?
Thank you really much
Hi @Antoine_Varraso :wave:
Do you want to track clicks on the chat bubble (1) or Start Chat button (2)?
Both if it’s possible sir
Sure! Here is the code that should be added to the Custom JS field on the Appearance tab of your widget’s settings:
function sendAnalyticsEvent(config) {
        ga('send', 'event', {
            eventAction: config.action,
            eventLabel: config.label
            'event_label': config.label
    const matchingItems = [
            selector: '[class*="Bubble__BubbleComponent"]',
            label: 'Open/Close Chat Widget'
            selector: '[class*="ChatButton__DefaultButtonComponent-sc"]',
            label: 'Click Start Chat Button'
    matchingItems.forEach((item) => {
        const match = event.target.closest(item.selector);
        if (match) {
            sendAnalyticsEvent({
                action: 'click',
                category: 'Elfsight Chat Widget',
                label: item.label
Try it out and let me know if it helped
Hello Max,
I installed the code on the custom JS field but I can’t see any interactions with the widget when I try with GTM preview mode.
Can you help me out?
Thanks
Please try to add this part to your website’s <head>:
gtag('js', new Date());
gtag('config', 'G-ID');
If there is no way to add it to the <head>, paste it next to the widget’s installation code.
Check it out and let me know how it worked :slightly_smiling_face:
